the new printer I have won’t setup but if I go to terminal it says cups is not installed I’m on ubuntu 11.10 please help would I use the sane program for the scanner dose it make a difference if its all in one?
I’d be seriously surprised if CUPS wasn’t installed.
Install the hplip-gui package:
sudo apt-get install hplip-gui
You should then find the HPLIP Toolbox in the menu’s somewhere … Set your printer up in there.
SANE is a command line application, and the backend for scanning applications like Simple Scan and Xsane.
I’d suggest Xsane:
sudo apt-get install xsane
OK …
What is the output from
dpkg -l hplip
What happens if you (in your web browser) go to:
http://localhost:631/
then select … Administration > Find New Printers
I’m doing this from memory … but what happens if you click the blue writing (HP-Deskjet-1050-J410-series) on the screen in your pic … does it let you add the printer ?
if not, go back to Administration > Add Printer
If it asks for a username/password … it’s your Linux ones it wants.
Dunno … try it and see … you can always remove it if it doesn’t in Administration > Manage Printers
According to the HPLIP website, the drivers for your printer have been included since hplip-3.10.6
You are on a more recent version … so they’re on there somewhere.
Did you try Administration > Add Printer ?
Have you tried adding it through the system settings panel … Ubuntu >= 11.04 is supposed to be able to automatically detect and offer you the correct driver ?
It may be listed as J410
I take it the printer is working now ? … but not the scanner ?
What is the output from:
sane-find-scanner
sudo sane-find-scanner
scanimage -L
This is a USB printer, and not a wireless one ?
You could also try installing the latest version of hplip (3.12.4) … instructions and download here:
http://hplipopensource.com/hplip-web/install/install/index.html
Will you STOP opening multiple topics, when ALL of this should be being covered in your original topic:
http://linuxforums.org.uk/index.php?topic=10094.0
I’m now going to merge those 3 topics.
Merged, and PM sent to OP
OK, lets start from scratch, remove all the printers,and install the latest hplip …
In your web browser, go to
then go to Administration tab > Manage Printers
click the BLUE writing at the beginning of the line for the HP 1050 J410
Select the “Administration” drop menu … Select “Delete Printer”
Do this for ALL entries other than PDF if present.
Open a terminal and run:
sudo sytem-config-printer
If there are any printers in there (other than PDF) … right-click them, and select “Delete”.
Close the printing window.
Back in the terminal, run:
sudo apt-get remove hplip-gui
cd ~
wget http://prdownloads.sourceforge.net/hplip/hplip-3.12.4.run
sh hplip-3.12.4.run
then follow the instructions from Step3 on this page:
“a” was probably fine … but did it guess your Ubuntu version correctly ?
did it find your printer ?
If you open a terminal and run:
hp-setup
then go to the linked page above, and continue from step 11 … does it find your printer ?
What is in the “PPD File:” field ?
Are you saying that you couldn’t enter the CUPS web interface ? … Click this link in your browser:
does that take you to the CUPS web interface ? … what’s listed if you select Administration tab > Manage Printers
If there’s 4 of them, you need to delete them all, then when there’s NONE, run:
hp-setup
again and add just ONE copy.
I’m not understanding you, and you’re not answering my questions again :o
What happens if you click this link:
The CUPS username and password are you Linux ones
Can’t you delete them from within
hp-setup
or from within:
system-config-printer
Are you saying your Linux password no longer works ? … how are you logging on ?
You’ve lost me with the shortcuts, and cut and paste comments … and CUPS should accept your Linux username and password … have you tried creating a new user, making that user an administrator, then logging into that account and seeing if everything works.
If not, and your system is that messed up that it won’t accept passwords … maybe you should consider a fresh install … specially considering 12.04 was just released.
IIRC, your PC has played up since you upgraded 10.10 → 11.10
Your printer and scanner are supposed to just work.
You’ve lost me … You have the 12.04 LiveCD ISO image downloaded ? … if so, why are you trying to extract it ?
You need to burn the ISO image to a CD or DVD with something like Brasero … or use “Startup Disk Creator” to create a LiveUSB stick with it.
There are links on how to burn the CD in Ubuntu or Windows on the right hand column of this page:
http://www.ubuntu.com/download/desktop
Then boot to it.
I have no idea what “tails live image” is ???
How did you burn the ISO image to DVD ?
Yes, set the CD/DVD drive as the first boot device in the BIOS.
Or when your system is showing the POST screen … look for a message telling you what key to press to enter the boot device selection screen … usually F12 or F10
It won’t load the HP icon on to the top bar I also looked in applications for it but no luck
it takes me to cups if I click on the local link
It won’t let me passed the password to add printer, I think this is an error on my part can I delete account and restart(sorry)
found USB scanner (vendor=0x03f0 [HP], product=0x8911 [Deskjet 1050 J410 series]) at libusb:002:002 but when I select scan I get the error fail to start scan …device I/O
gordon@gordon-desktop:~$ scanimage -L
device `hpaio:/usb/Deskjet_1050_J410_series?serial=CN19D1N19C05QT’ is a Hewlett-Packard Deskjet_1050_J410_series all-in-one
I be back tomorrow should be about 6 pm
thanks for ur help so far
hp-check -t
I’ve attached the output it tells me theres no tray for exiting
OK first of all you have 3 print queues for that printer … click this link:
Then click Administration>Manage Printers … click the blue writing for each HP printer (in turn) and select “Delete Printer” from the Administration drop menu.
Make sure you’ve deleted ALL HP printer queues … we’ll add one back later, after sorting the other problems.
Secondly … you appear to have some missing run-time dependencies (for hplip) … With your printer turned ON, open a terminal and run:
hp-check -r
and post the output.
Here’s mine for comparison (Ubuntu 11.10 64bit):-
[spoiler]
mark@mark:~$ hp-check -rHP Linux Imaging and Printing System (ver. 3.11.7)
Dependency/Version Check Utility ver. 14.3Copyright (c) 2001-9 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.Note: hp-check can be run in three modes:
- Compile-time check mode (-c or --compile): Use this mode before compiling the
HPLIP supplied tarball (.tar.gz or .run) to determine if the proper dependencies
are installed to successfully compile HPLIP.- Run-time check mode (-r or --run): Use this mode to determine if a distro
supplied package (.deb, .rpm, etc) or an already built HPLIP supplied tarball
has the proper dependencies installed to successfully run.- Both compile- and run-time check mode (-b or --both) (Default): This mode
will check both of the above cases (both compile- and run-time dependencies).Saving output in log file: hp-check.log
Initializing. Please wait…
SYSTEM INFO Basic system information:
Linux mark 3.0.0-17-generic #30-Ubuntu SMP Thu Mar 8 20:45:39 UTC 2012 x86_64 x86_64 x86_64 GNU/LinuxDistribution:
ubuntu 11.10Checking Python version…
OK, version 2.7.2 installedChecking PyQt 4.x version…
OK, version 4.8.5 installed.Checking for CUPS…
Status: scheduler is running
Version: 1.5.0
error_log is set to level: warnChecking for dbus/python-dbus…
dbus daemon is running.
python-dbus version: 0.84.0
RUNTIME DEPENDENCIES Checking for dependency: CUPS - Common Unix Printing System…
OK, found.Checking for dependency: GhostScript - PostScript and PDF language interpreter and previewer…
OK, found.Checking for dependency: PIL - Python Imaging Library (required for commandline scanning with hp-scan)…
OK, found.Checking for dependency: PolicyKit - Administrative policy framework…
OK, found.Checking for dependency: PyQt 4 DBus - DBus Support for PyQt4…
OK, found.Checking for dependency: Python DBus - Python bindings for DBus…
OK, found.Checking for dependency: Python libnotify - Python bindings for the libnotify Desktop notifications…
OK, found.Checking for dependency: Python XML libraries…
OK, found.Checking for dependency: Python 2.3 or greater - Required for fax functionality…
OK, found.Checking for dependency: Reportlab - PDF library for Python…
OK, found.Checking for dependency: SANE - Scanning library…
OK, found.Checking for dependency: scanimage - Shell scanning program…
OK, found.Checking for dependency: xsane - Graphical scanner frontend for SANE…
warning: NOT FOUND! This is an OPTIONAL/RUNTIME ONLY dependency. Some HPLIP functionality may not function properly.
HPLIP INSTALLATION Currently installed HPLIP version…
HPLIP 3.11.7 currently installed in ‘/usr/share/hplip’.Current contents of ‘/etc/hp/hplip.conf’ file:
hplip.conf. Generated from hplip.conf.in by configure.
[hplip]
version=3.11.7[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip-doc/HTML
icon=no
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drvFollowing values are determined at configure time and cannot be changed.
[configure]
network-build=yes
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
foomatic-drv-install=yes
foomatic-ppd-install=yes
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.11.7
restricted-build=no
ui-toolkit=qt4
qt3=no
qt4=yes
policy-kit=yes
hpijs-only-build=no
lite-build=no
udev-acl-rules=yes
hpcups-only-build=no
hpijs-only-build=noCurrent contents of ‘/var/lib/hp/hplip.state’ file:
hplip.state - HPLIP runtime persistent variables.
[plugin]
installed=0
eula=0Current contents of ‘~/.hplip/hplip.conf’ file:
[installation]
date_time = 13/07/12 11:16:55
version = 3.11.7[settings]
systray_visible = 0
systray_messages = 0[last_used]
device_uri = “hp:/usb/Photosmart_C3100_series?serial=CN747C20BC04P9”
printer_name =
working_dir = .[commands]
scan = /usr/bin/simple-scan %SANE_URI%[refresh]
rate = 30
enable = false
type = 1[polling]
enable = false
interval = 5
device_list =[fax]
voice_phone =
email_address =
DISCOVERED USB DEVICES No devices found.
INSTALLED CUPS PRINTER QUEUES Photosmart-C3100-series
Type: Printer
Device URI: hp:/usb/Photosmart_C3100_series?serial=CN747C20BC04P9
PPD: /etc/cups/ppd/Photosmart-C3100-series.ppd
PPD Description: HP Photosmart c3100 Series, hpcups 3.11.7
Printer status: printer Photosmart-C3100-series disabled since Tue 13 Dec 2011 23:02:49 Unplugged or turned off
error: Unable to communicate with device (code=12): hp:/usb/Photosmart_C3100_series?serial=CN747C20BC04P9
error: Device not found
error: Communication status: Failed
SANE CONFIGURATION ‘hpaio’ in ‘/etc/sane.d/dll.conf’…
OK, found. SANE backend ‘hpaio’ is properly set up.Checking output of ‘scanimage -L’…
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
PYTHON EXTENSIONS Checking ‘cupsext’ CUPS extension…
OK, found.Checking ‘pcardext’ Photocard extension…
OK, found.Checking ‘hpmudext’ I/O extension…
OK, found.Checking ‘scanext’ SANE scanning extension…
OK, found.
USER GROUPS mark adm lp dialout cdrom audio plugdev lpadmin admin sambashare vboxusers
SUMMARY error: 2 errors and/or warnings.
Please refer to the installation instructions at:
http://hplip.sourceforge.net/install/index.htmlDone.
My Printer was turned OFF at the time, that’s why I got the errors[/spoiler]
Thirdly, your user account doesn’t appear to be in the “lp” group … open a terminal and run:
sudo apt-get install gnome-system-tools
then send the output from:
users; groups
The local host won’t let me past the password was I supposed to run this after deleteing the printers ?
gordon@gordon-desktop:~$ hp-check -r
HP Linux Imaging and Printing System (ver. 3.12.2)
Copyright (c) 2011-14 Hewlett-Packard Development Company, LP
are installed to successfully compile HPLIP. - Run-time check mode (-r or --run): Use this mode to determine if a distro
has the proper dependencies installed to successfully run. - Both compile- and run-time check mode (-b or --both) (Default): This mode
SYSTEM INFO |
Linux gordon-desktop 3.2.0-26-generic-pae #41-Ubuntu SMP Thu Jun 14 16:45:14 UTC 2012 i686 i686 i386 GNU/Linux
Distribution:
ubuntu 12.04
OK, version 2.7.3 installed
OK, version 4.9.1 installed.
Checking for CUPS…
warning: Version: (cups-config) Not available. Unable to determine installed version of CUPS.)
python-dbus version: 1.0.0
RUNTIME DEPENDENCIES |
OK, found.
Checking for dependency: CUPS DDK - CUPS driver development kit…
OK, found.
OK, found.
OK, found.
OK, found.
OK, found.
OK, found.
OK, found.
OK, found.
OK, found.
OK, found.
OK, found.
OK, found.
HPLIP INSTALLATION |
HPLIP 3.12.2 currently installed in ‘/usr/share/hplip’.
[hplip]
version=3.12.2
[dirs]
run=/var/run
icon=no
[configure]
network-build=yes
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
hpcups-install=yes
cups-ppd-install=no
internal-tag=3.12.2
restricted-build=no
ui-toolkit=qt4
qt3=no
qt4=yes
policy-kit=yes
hpijs-only-build=no
lite-build=no
udev-acl-rules=yes
hpijs-only-build=no
[plugin]
installed=0
eula=0
[settings]
systray_visible = 0
[last_used]
device_uri = “hp:/usb/Deskjet_1050_J410_series?serial=CN19D1N19C05QT”
printer_name =
working_dir = .
[commands]
[refresh]
rate = 30
enable = false
type = 1
[polling]
enable = false
interval = 5
device_list =
[fax]
voice_phone =
email_address =
[installation]
date_time = 13/07/12 18:26:19
version = 3.12.2
DISCOVERED USB DEVICES |
Device URI Model
hp:/usb/Deskjet_1050_J410_series HP Deskjet 1050 J410 series
INSTALLED CUPS PRINTER QUEUES |
Deskjet_1050_J410
Type: Printer
Device URI: hp:/usb/Deskjet_1050_J410_series?serial=CN19D1N19C05QT
PPD: /etc/cups/ppd/Deskjet_1050_J410.ppd
PPD Description: HP Deskjet 1050 j410 Series, hpcups 3.12.2
Printer status: printer Deskjet_1050_J410 disabled since Fri 25 May 2012 21:26:55 BST - Backend /usr/lib/cups/backend/hp does not exist!
Communication status: Good
Deskjet_1050_J410_2
Type: Printer
PPD: /etc/cups/ppd/Deskjet_1050_J410_2.ppd
PPD Description: HP Deskjet 1050 j410 Series hpijs, 3.12.2
Printer status: printer Deskjet_1050_J410_2 disabled since Sat 23 Jun 2012 23:15:42 BST Backend /usr/lib/cups/backend/hp does not exist!
Deskjet_1050_J410_3
Type: Printer
PPD: /etc/cups/ppd/Deskjet_1050_J410_3.ppd
Printer status: printer Deskjet_1050_J410_3 disabled since Mon 09 Jul 2012 20:40:48 BST Backend /usr/lib/cups/backend/hp does not exist!
DJ
Type: Printer
PPD: /etc/cups/ppd/DJ.ppd
Printer Backend /usr/lib/cups/backend/hp does not exist!2 21:36:39 BST -
Type: Unknown
Device URI: usb://HP/Deskjet%201050%20J410%20series?serial=CN19D1N19C05QT&interface=1
PPD: /etc/cups/ppd/HP-Deskjet-1050-J410-series.ppd
Printer status: printer HP-Deskjet-1050-J410-series now printing HP-Deskjet-1050-J410-seProcessing page 1…ce Fri 13 Jul 2012 18:18:48 BST
warning: Printer is not HPLIP installed. Printers must use the hp: or hpfax: CUPS backend to function in HPLIP.
SANE CONFIGURATION |
‘hpaio’ in ‘/etc/sane.d/dll.d/hplip’…
PYTHON EXTENSIONS |
OK, found.
OK, found.
OK, found.
OK, found.
USB I/O SETUP |
Checking for permissions of USB attached printers…
HP Device 0x8911 at 002:002:
Device node: /dev/bus/usb/002/002
Mode: 0664
getfacl: Removing leading ‘/’ from absolute path names
file: dev/bus/usb/002/002
owner: root
group: lp
user::rw-
user:gordon:rw-
group::rw-
mask::rw-
other::r–
USER GROUPS |
gordon adm cdrom sudo dip plugdev lpadmin sambashare
error: User needs to be member of group ‘lp’ to enable print, scan & fax.
User member of group ‘lpadmin’.
SUMMARY |
Done.
I run it after and get this on the end
PYTHON EXTENSIONS |
OK, found.
OK, found.
OK, found.
OK, found.
USB I/O SETUP |
Mode: 0664
owner: root
group: lp
user::rw-
user:gordon:rw-
group::rw-
mask::rw-
other::r–
USER GROUPS |
SUMMARY |
Done.
the printer is switched on with the USB connected ?
OK, first open a terminal and run:
users-admin
In the window that opens, click “Manage Groups”
In the new window, scroll down to “lp”, click it (to highlight it) and click “Properties”
In the new window, put a tick in the little box by your username, and click “OK” … enter your password when asked, then close all windows.
Now REBOOT … once rebooted, run:
groups
and check you are now in the “lp” group.
Now in your Web Browser, go to:
and delete ALL HP printer queues … when it asks for a username/password, they are your Ubuntu username and password you need to enter.
When you’ve deleted ALL HP printer queues … open a terminal and run:
hp-toolbox
If the HP Toolbox opens, set up your priter in there.
