I am trying to install another OS in my KVM but I see this error in the process of installing another OS to run in the VM.
‘Warning KVM is not available. This may mean the KVM package is not installed, or the modules are not loaded. Your virtual machines may perform poorly.’
OK, the Athlon 64 X2 5200+ was a “Windsor” CPU, sodoes support AMD-V (AMD’s hardware virtualisation acceleration), and this is confirmed by the “svm” flag from cpuinfo.
So I can only assume that resetting the BIOS has turned off hardware virtualisation support in the BIOS … look in your BIOS for an option to turn it back on.
I’m also getting this error (if you could call it such), where the dialogue boxes are slightly off-screen!
Including the error reported in the boxes, the VM can’t access external drives!
I’ve not yet installed Manjaro in the VM as SeZo points out, the VM can’t access the NTFS drive
So I will have to put a copy on another drive…
@Mark - Did you notice the placement of the dialogue boxes… Right at the TOP of the screen… Cutting off the top of the box…
How do/can i move them or even get them to be displayed in the centre of the screen?
Got right near the end and got this error!
Unable to complete install: 'internal error Process exited while reading console log output: Error opening file for reading: Permission denied
char device redirected to /dev/pts/0
kvm-spice: -drive file=/var/lib/libvirt/images/Manjaro.img,if=none,id=drive-virtio-disk0,format=raw: could not open disk image /var/lib/libvirt/images/Manjaro.img: Permission denied
I know nothing about KVM so cannot help you on this but would ask if this is even necessary as you have managed to install it once before. So you can do it again (just smake sure you skip the grub install).
I think MP knows more about KVM so should wait for him to see the thread or should I give him a nudge?
Anyways… I think this little problem has more to do with ownership of the file (CHOWN)
But I cant remember how to change it to let ‘all’ use it…
I’ve gone into ‘Properties’ and changed the permissions there but it still wont let me install Manjaro!
Well no, it won’t be the desktop environment if it’s not getting as far as the login screen … the desktop is loaded after the login screen (which is why you get to choose an environment at that screen).
