Hey guys I’m not sure if this is a Firefox or Linux issue, but as you guys are IT experts I shall ask you anyway.
On my wordpress blog the widgets don’t work- I do all the settings one is supposed to do but they don’t appear on my blog. The wordpress forum people haven’t got a clue why they won’t work.
I seriously doubt if it’s either … more likely a wordpress configuration issue.
But there’s nothing stopping you testing the site in chrome
Figured it out Mark- I had to go back into the design and set the page to text and column! Thanks.
No worrries … glad you figured it out in the end, Wordpress template configuration can be a bit tricky at first (sooooo many options)
Yes, took me a few months to get au fait with it Mark!
