Wifi setup issue in fedora 20
Hello,
I have recently installed , Fedora 20 Os in my PC but the Wireless don’t work .
Can anyone help me to fix this ?
Yum install command fails saying “Cannot retrieve metalink for repository: fedora/20/x86_64.”
Rfkill command fails saying “command not found”
Thank you.
Pankaj
What is the output from:
lshw -c network
Hi,
Command lshw -c network says: command not found.
Thanks!!
Ugh, I forgot that Fedora doesn’t include lshw, and I can’t remember if you can add it via yum.
Can you post up:
lspci
Hi,
Command lspci results in:
$ lspci
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b)
00:03.0 Audio device: Intel Corporation Device 0a0c (rev 0b)
00:14.0 USB controller: Intel Corporation Lynx Point-LP USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation Lynx Point-LP HECI #0 (rev 04)
00:1b.0 Audio device: Intel Corporation Lynx Point-LP HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 3 (rev e4)
00:1c.3 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 4 (rev e4)
00:1c.4 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 5 (rev e4)
00:1d.0 USB controller: Intel Corporation Lynx Point-LP USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation Lynx Point-LP LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation Lynx Point-LP SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation Lynx Point-LP SMBus Controller (rev 04)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b723
03:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M / GT 620M/625M/630M/720M] (rev a1)
Thanks!!
Are you connecting to the router via an ethernet cable when you get the yum error ?
See here:
http://codeketchup.blogspot.co.uk/2014/01/how-to-fix-cannot-retrieve-metalink-for.html
Hi,
Not connected to internet while trying yum command. Is it required ?
Thanks!!
Yes it is … yum’s job is to download and install software and updates.
