hi all
i’am looking for a new operating system, before i make a move to linux would like to know if iracing will run on it, any help would be nice thanks
The iRacing website says it requires a “Windows based PC”, it doesn’t even run on an Apple Mac unless booted into Windows using Boot Camp… I can find nothing online, or in the WINE App database that says it will run Under WINE… so I’m afraid you’re probably out of luck
But it might be worth asking on the GamingOnLinux forum… they will be happy to advise further.
GamingOnLinux Forum, here:
http://www.gamingonlinux.com/index.php?forum/
Sorry I couldn’t help you more.
rFactor on the other hand is listed as “Platinum” on the WINE APP Database:
http://appdb.winehq.org/objectManager.php?sClass=application&iId=2678
Now, I would’ve answered this question if I hadn’t had paid for LFS rather than iRacing. But iRacing was supposed to cost a fortune just to upgrade. I wish I had paid so that I could’ve answered your question mate, sorry
thanks for your in put, i check with the GamingOnLinux Forum, just need to find out before i renew my membership with them.
looking on the bright side i also have rFactor and it will save me some money not renew anyway.
thanks again
