window/desktop change thing
im new to linux but ive heard a lot about it
on the homepage for linux.com theres one screen shot of the scrolling desktop thing halfway through changing, and it zooms out and then rotates, but all mine does is swipe, how do you get it to do that?
thanks for any help
Daniel . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / . . . _ _ _ . . . / if your wondering this is morse code for SOS
Go to System>Preferences>CompizConfig Settings Manager
Put a tick in Desktop Cube and Rotate Cube
Now if you hold Ctrl+Alt+Left Mouse Button, and move the mouse… the cube will rotate.
If there is no CompizConfig Settings Manager in the menu… you’ll need to install the compizconfig-settings-manager package and it wouldn’t hurt to install compiz-fusion-plugins-extra at the same time
These can be installed (graphically) from within the Synaptic Package Manager, or from a terminal with this command:
sudo apt-get install compizconfig-settings-manager compiz-fusion-plugins-extra
Have fun playing with Compiz… :slight_smile:
thanks
