Hi All
Im trying to sort out the Wireless Card - TP link. I cant seem to load the driver from their website. Does any one know what would be best for a TP Link 54 bps TL WN550G PCI Adaptor?
Hi All
Can you open a terminal and run the following commands, and post the output back here:
lspci | grep Subsystem
sudo lshw -C network
ifconfig
sudo iwlist scanning
rfkill list
and remember, Linux commands ARE case sensitive.
Just to give you confidence, Will, I bought the following TP-Link products:
TP-Link TD-W8960N Wireless Router-Modem
TP-Link TL-WN822N 300MBPS Wireless N USB Adapter
The adapter failed after a few minutes and the router failed slowly over two months or so - I was blaming BT, since the wireless bit worked, but my spare modem works fine.
Thought that would cheer you up!
Oh dear … not exactly a hearty recommendation then :o
Certainly a confidence booster. :o
Sarcasm btw!
